Date/Time: Wed, 15 Jan 2025 19:53:09 +0000
Can Sierra Chart connect to more then on Data Trade service?
View Count: 1070
[2017-09-07 13:22:28] |
User572924 - Posts: 3 |
in the Data/Trade Service setting menu , there is range of data service selection. My question is can Sierra Chart connect to more then on service? e.g connect the sc Data AND FXCM at the same time? |
[2017-09-07 17:01:34] |
Yes, refer to the instructions here: Using Multiple Data and Trading Services at the Same Time With FXCM, did you want to trade or did you just need the market data? If you just need market data, there is no reason to use 2 separate services. You can open the FXCM symbols through File >> Find Symbol >> Forex/CFD with most other services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
