Date/Time: Wed, 15 Jan 2025 19:33:27 +0000
Sierracharts Request 07/09/17
View Count: 753
[2017-09-07 08:26:23] |
fs26 - Posts: 7 |
Hello Support, Do you have a complete video explaining all the options available in the trade window ? These are numerous and great difficulties to find one on the web to be honest ! Besides, I would like if these orders could be done onto Sierra ? A > create 2 orders simultaneously, one sell and one buy with a specific target in ticks for each and a specific stop (hard stop, traililng stop) B> create an order that trigger a trailing stop when, for example, 3 ticks are touched: OK. but adding a secondary action with no human intervention which would be: At this step, the strategy would open a second order at the 4th tick touched and at the same time placing the stop loss placed at breakeven C> customise a breakeven to +1tick by default ? (a stop win that take into consideration the broker commision: 1 tick for one contract) D> When an order is closed, the relative notes do not comes out on the chart anymore. I do not know how to show them back. D> Are there some communities of developpers specialised on Sierracharts to which it would be possible to ask custom indicators or strategies building ? Suggestion: all you internal windows cannot be increased in size from a corner, which makes difficult the use of the interface. Graphics Settings...for example... Could you change that ? Thanks a lot four kind help, |
[2017-09-07 19:11:31] |
Refer to the documentation here for the Trade Window: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html Here is the documentation for Order Types: http://www.sierrachart.com/index.php?page=doc/OrderTypes.html Here is the documentation for Attached Orders: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html D> When an order is closed, the relative notes do not comes out on the chart anymore. I do not know how to show them back. D> Are there some communities of developpers specialised on Sierracharts to which it would be possible to ask custom indicators or strategies building ? https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php Suggestion: all you internal windows cannot be increased in size from a corner, which makes difficult the use of the interface. Graphics Settings...for example... Could you change that ? http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#AdjustingSizeOfDialogWindows Detailed support and further support will require a paid account and additional charges for support at 50 USD per hour. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-07 19:12:05
