Date/Time: Wed, 15 Jan 2025 17:37:23 +0000
Not able to read 6C candles
View Count: 559
[2017-09-06 21:11:01] |
User942178 - Posts: 25 |
Was there a problem on the 6C today? Other than 9:00 to 10:00 all the candles before and after are in a very straight line with no way to distinguish the candles. I have a screenshot but not able to attach.
2017-09-06.png / V - Attached On 2017-09-06 21:00:22 UTC - Size: 122.13 KB - 233 views Attachment Deleted. |
[2017-09-06 23:13:29] |
We just recommend that you reset the scale with Chart >> Reset Scales to get a better view of the chart: Chart Menu: Reset Scales (Chart menu) Otherwise, everything looks normal and what you see makes sense based on the price action. Also here are instructions to post an image of a chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-06 23:14:34
