Date/Time: Wed, 15 Jan 2025 17:52:52 +0000
[User Discussion] - Spreadsheet trading system
View Count: 569
[2017-09-06 17:08:03]
User39772 - Posts: 311
Hello, when my buy conditions is met I see a green arrow in the chart but no orders are sent to my trading service (feature is set to; YES).
Additionally I see many arrows when the entry condition was met in the past. is it possible to show only the latest entry condition ?
[2017-09-06 17:16:46]
All of this is explained in this section here:
Spreadsheet Systems, Alerts and Automated Trading: Ignored Signals With Spreadsheet Systems or Alerts
You could try reducing the Number of Rows input with the Spreadsheet study:
Spreadsheet Study Inputs
[2017-09-06 18:40:50]
Thank you.
If I calculate my entry position size in column J26 depending on the market volatility the value here changes after an entry.
If my exit condition is met the value in this cell will be used for exit also which leads to partially open positions.
Is there a way to use cell J26 only for entry and to exit always the full open position ?
