Date/Time: Wed, 15 Jan 2025 20:52:46 +0000
chart display becomes faulty when Chart DOM is on and switching between chartbooks
View Count: 881
[2017-09-06 13:15:31]
cross - Posts: 70
Version: 1607 pre-release
- create two chartbooks
- add one chart to both
- turn on chart dom on any
- switch between the chartbook
- switching back to the one with chart dom on makes the chart shifting left on all mouse move
- finally all the chart space becomes empty
I hope this helps.
[2017-09-06 14:47:21]
cross - Posts: 70
Moreover, an Attached Trade Window (on the left side, OCO, etc) also diappears after switching back and forth between chartbooks where the chart has Chart DOM on.
[2017-09-06 16:43:27]
We will look these over and resolve. There have been changes in this latest prerelease to destroy a chart window when it is not visible.
[2017-09-06 17:04:20]
cross - Posts: 70
The cause might be different but using a custom study (dll) which I compiled with FreeDLL set to true for testing resulted in memory accumulation for the SC instance. As far as I can remember this was not the case in the past.
However, I did not put too much work into this. I mean the instance did not run long enough to conclude as it seemed that FreeDLL set to false stopped (or slowed?) this.
I can test it further tomorrow if needed.
[2017-09-06 17:10:30]
We do not need any further information.
[2017-09-11 13:10:04]
cross - Posts: 70
[...] destroy a chart window when it is not visible.
Question:
If I have an automated trade management study or other auto-trading ACSIL / spreadsheet on a chart which is destroyed when I switch to a different chartbook tab or a full screen chart (in the same chartbook?) then will it STILL trail or trade in the background?
PS: I've just seen the new pre-release but I haven't tried the above
Date Time Of Last Edit: 2017-09-11 13:14:22
[2017-09-11 16:12:22]
The answer to the question is yes.
