Date/Time: Wed, 15 Jan 2025 17:47:49 +0000
Windows XP: which VC++ Runtime version?
View Count: 854
[2017-09-06 07:23:54]
Lesmond - Posts: 22
I'm building a clean installation of Windows XP (with POSReady updates) dedicated to running SC and IB TWS (all other tasks are done in Linux Lite and Arch Linux on another machine). I have the following components shown in the old installation:
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2008 Redistributable
Microsoft Visual C++ 2010 Redistributable
Microsoft Visual C++ 2008 Express Edition with SP1
According to the release log the last versions of SC compiled to support Windows XP are:
1504
1547-1563
Which VC++ Runtime should be used with SC versions shown above? I can see the following runtimes available:
2005
2008
2010
2012
2013
2015/2017
I realize that SC is primarily tested on Windows 7 but I have more experience with XP, a switch over to Win7 is on to-do-later list.
[2017-09-06 16:19:54]
The current Sierra Chart versions still do support Windows XP and there are no redistributables required.
There is nothing special to do here.
