Date/Time: Wed, 15 Jan 2025 18:00:33 +0000
Different Volume
View Count: 759
[2017-09-06 03:32:02]
nicktrader - Posts: 728
As you can see in the attached file there is a big difference between das "Daily Volume" in the chart header and the Volume of the "candlestick - data".
What is the reason for such a big difference?
imageVolume EURO BUND.png / V - Attached On 2017-09-06 03:31:25 UTC - Size: 16.99 KB - 263 views
[2017-09-06 04:24:47]
Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7
