Date/Time: Sun, 09 Feb 2025 03:02:38 +0000
DOM OCO BRACKET ORDERS
View Count: 2469
[2017-09-06 02:15:22]
Trader&Hunter - Posts: 131
I am trying to set up an order for 6 contracts, 12 tick stop, after 6 ticks, take half position off and move stop to minus 6. the remainder contracts I will trail myself. How can I do that?
[2017-09-06 17:31:06]
This can be done with Attached Orders:
Attached Orders
You will also need to use the Move to Breakeven for Stops settings:
Attached Orders: Move to Breakeven for Stop
You will want to use 2 Targets and one common stop.
Date Time Of Last Edit: 2017-09-06 17:32:03
[2020-08-06 15:40:54]
User209280 - Posts: 4
Is there a way to use the bracket orders I created on the DOM when trading directly on the charts?
[2020-08-06 18:51:43]
If you have saved a Trading Configuration, then this is available in both places. Refer to the information here:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
Also, your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-08-06 18:57:51]
Yes, in the DOM, but if I want to take a trade by right clicking on the chart and have my brackets order on the menu?
[2020-08-06 19:08:47]
Yes you can do this just by submitting an order and the Attached Orders will be attached:
Attached Orders: Step-By-Step Instructions
