Date/Time: Wed, 15 Jan 2025 17:51:00 +0000
Previous High, Low and Last in Custom Study
View Count: 1374
[2017-09-05 19:36:59] |
User956467 - Posts: 30 |
An existing SC Study formula uses the current bar high, low and last. I have used SC instructions (jEdit etc.) to copy the ACSIL code and save as a custom study. My desire is to use the PREVIOUS high, low and close in the new custom study. In the new custom study how do I change the current high, low and close to the PREVIOUS bar high, low and close. Thanks!
[2017-09-05 19:49:05] |
Refer to this page for an understanding of this: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
