Date/Time: Tue, 15 Sep 2026 18:36:01 +0000
Changing X and Y axis font size
View Count: 2306
[2017-09-05 18:49:58]
User780238 - Posts: 45
Can you make the times at the bottom of the chart, and the price levels on the side of the chart, bigger or at least bolder?
[2017-09-05 19:07:16]
Yes. Refer to:
https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#Fonts
[2021-01-04 14:50:46]
WhiskyTango - Posts: 8
hi, i'm in the fonts tab but whats name of the text on the y-axis?
cant seem to change the colour, and its not using Global Graphic settings.
also whats a MDI tab stand for?
[2021-01-04 17:37:44]
John - SC Support - Posts: 47901
To change the X and Y axis font, you need to change the Global Settings >> Graphics Settings - Global >> Fonts >> Chart Text. Note that this is the general text, so it will change more than just the X and Y axes. Refer to the information here:
Graphics Settings: Chart Text
If you want to change the color for the X and Y axes, then that is done from the Colors and Widths tab on that same page. Refer to the following:
If you are making these changes on the Graphics Settings - Global page and it is not updating your chart, then the chart must be set to use Chart Specific settings. In which case, you would need to go to Chart >> Graphics Settings - Chart, to make the changes. Refer to the information here:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
MDI stands for Multi-Document Interface. The tabs at the bottom of the Chartbook (by default) can display Charts and Spreadsheets, therefore this was the name that was given to them.
