Date/Time: Wed, 15 Jan 2025 17:53:33 +0000
TPO for $SPX
View Count: 1476
[2017-09-05 17:57:54] |
User68876 - Posts: 5 |
Hello, can you help me with TPO which is not displaying on SPX but on SPY is correct. It writes symbol is unknown. exchange is not authorized. Which exchange needs to be authorized? thanks
[2017-09-05 18:09:16] |
Use the symbol $INX and if there is a problem provide an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-05 18:58:35] |
@INX works, thanks. What about $VIX. Does it have any equivalent too?
[2017-09-05 19:08:06] |
No, if the study with that symbol is not working as expected post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-05 19:08:36
[2017-09-05 19:24:19] |
Hi, here is link with $VIX when it displayed TPO and later on not. http://www.sierrachart.com/image.php?Image=1504639345579.png |
[2017-09-05 19:29:18] |
You are using the Volume by Price study and not the TPO Profile Chart study. Here is the documentation for the TPO Profile Chart study: Time Price Opportunity (TPO) Profile Charts There is no volume data for $VIX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-05 19:29:54
[2017-09-05 19:33:42] |
You are right, volume by price, but why it was displaying this profile 3times earlier and now not in $VIX?
[2017-09-05 19:45:51] |
Previously there was volume based upon the number of price updates but that was never accurate.
[2017-09-05 19:55:19] |
OK, I do not need it to be accurate, it is enough to be based upon the number of price. Can you explain me how to do it? thanks
[2017-09-06 04:43:43] |
What we need to do is start maintaining the volume based on the number of price updates. We are looking into that now. Please allow 2 to 3 days for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
