Date/Time: Wed, 15 Jan 2025 17:56:20 +0000
Stop Limit executed one tick to my disadvantage
View Count: 887
[2017-09-05 17:10:39]
pkhst958 - Posts: 57
Hi all, a Stop Limit Order was executed one tick to my disadvantage. How can that be? Is there a settinge for Limit not being to the point but with a minor offset?
[2017-09-05 18:28:19]
Yes, there is offset setting for the Limit order. Refer to:
Order Types: Stop-Limit
[2017-09-06 04:49:28]
Do I understand correctly - if I set in the Tab Set the primary order to 0, then it wll only be executed on the exact limit or better for me?
My attached orders do not have stop limits, so in the Tab Set the attachend orders are not relevant. Right?
[2017-09-06 05:48:42]
Yes, all of this is a correct understanding.
