Date/Time: Wed, 15 Jan 2025 18:02:27 +0000
CQG Server closer to Europe?
View Count: 1258
[2017-09-05 13:29:14] |
User155152 - Posts: 10 |
Hello I use Sierra Chart with CQG. I connect from Italy. when I am pinging the CQG server used by Sierra Chart (288.46.16.214) I have a latency 3 times as much as the latency I have when connecting to CQG (195.166.124.205) via CQG QTrader. The pings are roughly 180ms on the first case vs 65ms on the latter. any suggestion how can i improve it if at all possible? thanks |
[2017-09-05 15:14:27] |
We do not think CQG has another available server for their web API.
