Date/Time: Wed, 15 Jan 2025 17:57:23 +0000
Session Times
View Count: 1153
[2017-09-05 12:38:55] |
ecerejo - Posts: 16 |
Is there way of making the default times at 22:00:00 for start Time and 21:59:59 for End Time! For some reason my charts keep going back to 00:00:00 for Start Time and 23:59:59 End Time, for example if I change symbols, the chart will reset itself to 00:00:00 for start time and 23:59:59 End time and few other actions on the chart will cause this like going from Intraday Chart to Historical chart and back from Historical to Intraday, it's really annoying and time consuming!
[2017-09-05 15:52:55] |
jimskin - Posts: 127 |
I had the same issue. Try unchecking this option (Global Settings >> Symbol Settings >> Apply Intraday Session Times to Intraday Chart)and setting the Start/End Session times for each individual chart. Chart Session Times: Automatically Setting Session Times |
[2017-09-05 19:05:46] |
You need to set the Session Times on the symbol pattern in the Global Symbol Settings: Global Symbol Settings Also refer to: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-05 19:06:04
