Date/Time: Wed, 15 Jan 2025 18:05:45 +0000
Error Loading Custom Study
View Count: 800
[2017-09-05 10:38:31] |
User75439 - Posts: 18 |
Hi, I have "zones" plotted on a daily basis, upload as study, import DLL file into ES chart (s&p future chart). I did change computer recently and since than, I received the following error "Windows error code 193. 1% is not a valid win32 application. I do have a system with 64 bit. Could you please advise what can be the solution ? Regards Dan |
[2017-09-05 16:47:46] |
You will need to contact the developer of the custom studies DLL file about this. We do not know what to say about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
