Date/Time: Wed, 15 Jan 2025 19:56:56 +0000
DTCBridge on Linux
View Count: 1575
[2017-09-04 17:22:23] |
Jezz - Posts: 33 |
Hi I've been testing SC on linux under wine, and looks to work fine. Unfortunately I could not connect to Rithmic Because DTCbridge.exe closes. Couple of questions: Is DTCBridge.exe tested on Linux? Do you know if it requires any special library or DLL? When launched from command line, It gives an error requiring port. Any info on commandline command in order to watch what does terminal prints when launched, as a clue for possible requirements? Thanks in advance Date Time Of Last Edit: 2017-09-04 17:22:50
[2017-09-04 18:28:31] |
This is not something we will provide any help with since the issues are not within our control. The bridge program substantially consists of software from Rithmic. We do not recommend using Rithmic unless you have no other choice to use it. We recommend CQG or CTS instead: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-13 21:21:31] |
Jezz - Posts: 33 |
SOLVED After installing winehq instead of wine and wine-momo, DTCBridge looks to work fine on linux ! |
[2017-09-14 10:17:51] |
ganz - Posts: 1048 |
Jezz hey ... installing winehq instead of wine
https://www.winehq.org/ and wine-momo
https://www.nzwine.com/en/winery/momo-wines ? or did you mean just Mono? so what did you do, bro ? :) |
