Date/Time: Wed, 15 Jan 2025 17:51:45 +0000
Volume By Price study, numbers divider
View Count: 829
[2017-09-04 10:26:04] |
User514370 - Posts: 62 |
Hi SC, here is the VBP study with Ask-Bid Volume and Total Volume numbers. Is possible to add any kind of divider between these two numbers, like separate them by a comma? Or maybe a better option, have two align options? One number is aligned to the base of VBP study and the second one not. Thank you for your great work! |
vbp_divider.PNG / V - Attached On 2017-09-04 10:25:40 UTC - Size: 4.92 KB - 277 views |
[2017-09-04 18:53:29] |
We will add a divider between them. That is easiest to do.
