Date/Time: Wed, 15 Jan 2025 18:06:30 +0000
Sierra Chart Real-Time and Historical Exchange Data Feed HKFE not listed
View Count: 1206
[2017-09-03 15:43:19] |
User978290 - Posts: 25 |
Hi, I'm about to activate the real time data but I'm unable to find HKFE to activate. I have activated Real Time Exchange and Full Cme group. Thanks. Regards Law |
[2017-09-04 17:19:28] |
This is because you are in Hong Kong and in Hong Kong this data feed is available through only a particular trading educator. We can refer them to you if you would like. Let us know. Also, in regards to CME data, you need to connect Sierra Chart to your trading account to receive the real-time CME data when using the particular CME exchange fee you activated: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-04 17:29:52
[2017-09-04 17:30:21] |
The prior post has been updated.
