Date/Time: Wed, 15 Jan 2025 17:38:07 +0000
Concerning previous Sierra Chart Posts:50998
View Count: 847
[2017-09-02 21:39:37] |
User68474 - Posts: 201 |
Not sure if I should have restarted this conversation by continuing on the old chain or not. I'll start here. I've noticed in the most recent "updates to current version", that the "Chart Drawing Properties"/Anchors now has a "Line ID: xxxx' Reference number. Can I assume this is a result of what you stated you would be doing so that a Horizontal Line could be referenced in an alert formula (as per our Support Board Discussion/chain). If this is the case, what would be the proper "syntax" and/or "name" to use in adding to my alert formula? I have tried many ways, but keep getting "Error" messages. Is there an "SG.#"subgraph to be included with the ID ?
[2017-09-02 22:08:53] |
Post in same thread/support request. We have not started this feature task yet.
