Date/Time: Wed, 15 Jan 2025 20:48:04 +0000
Menu links are not working
View Count: 1893
[2017-09-08 20:50:12]
OK we see the condition under which this occurs. We will resolve.
[2017-09-09 18:40:28]
User461960 - Posts: 18
As far as running Sierra chart at peak performance on my computer is it better to upgrade RAM or upgrade to SSD drive? I currently have 32GB RAM.
For SSD should I install the operating system and sierra chart on it or just sierra chart? Also is the read speed or write speed of SSD more important for Sierra Chart?
[2017-09-09 21:29:24]
32 gigabytes is plenty of memory. Even some of our servers do not even have more memory than that. Although some of them do have 128 gigabytes.
The SSD should both be for Windows and Sierra Chart.
The reading speed is what is most important. Writing speed is not that important because that is done on another thread and on a delay.
Date Time Of Last Edit: 2017-09-09 21:29:59
[2017-09-12 03:43:57]
Is the graphics also important? What specs do you recommend for the GPU?
Also is the pre-release out with the t&s issue fixed?
[2017-09-12 04:40:44]
Please do not update to a new version. We are still working on the windows improvements related to destroying chart windows.
Just standard onboard graphics are fine.
