Date/Time: Wed, 15 Jan 2025 18:04:31 +0000
Volume by Price - All Visible Bars
View Count: 1469
[2017-09-02 11:51:50]
User99934 - Posts: 227
http://www.sierrachart.com/image.php?Image=150435224341.png
My setting are attached in pictures. What is proper way to send you my settings when I post a pic?
On the attached chart at time 16:02 the volume of 1 is out of proportion. At 16:04 the volume of 3 is out of proportion.
image1.PNG / V - Attached On 2017-09-02 11:45:19 UTC - Size: 28.05 KB - 380 views
image2.PNG / V - Attached On 2017-09-02 11:45:26 UTC - Size: 31.57 KB - 336 views
image3.PNG / V - Attached On 2017-09-02 11:45:34 UTC - Size: 33.55 KB - 314 views
image4.PNG / V - Attached On 2017-09-02 11:45:43 UTC - Size: 34.5 KB - 328 views
[2017-09-03 01:17:21]
As a charkbook:
The reason you see what you do is because the Bid Volume and Ask Volume coloring is based upon a diagonal difference. So the width of the volume bars are going to be based upon that.
We will add a corresponding Volume Bar Calculation Method and also a Display Volume in Bars for this.
Date Time Of Last Edit: 2017-09-03 01:18:15
