Date/Time: Wed, 15 Jan 2025 17:40:46 +0000
Daily volume issue
View Count: 811
[2017-09-02 10:18:04] |
User514370 - Posts: 62 |
Hi SC, I hit the volume issue. Please take a look at the picture. Daily volume in the chart header shows DV 723 167, but the volume study shows only 555 562. I believe my chart or trade service setting is correct. My data feed vendor is CQG. Also, checked the daily volume on Nymex and the correct number is DV in the chart header. Thank you. |
volume_issue.PNG / V - Attached On 2017-09-02 10:17:55 UTC - Size: 78.01 KB - 283 views |
[2017-09-02 11:04:46] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
