Date/Time: Wed, 15 Jan 2025 17:57:28 +0000
Can't change drawing y axis using UseRelativeVerticalValues in non chart graphregion
View Count: 830
[2017-09-01 22:39:47] |
User735389 - Posts: 189 |
I'm trying to add text drawings to a graph region below the chart, using UseRelativeVerticalValues. No matter what i specify, it'll draw all text at position 100. When I switch the study to graphregion 0 (in the chart), it will draw properly on the Y axis. I'm basically trying to draw some text in a grid in a non-chart region.
[2017-09-05 18:50:23] |
We added a new paragraph in this section here about this: https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#UseRelativeVerticalValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
