Date/Time: Wed, 15 Jan 2025 17:36:15 +0000
Hiding a chart to only show the bottom graph region
View Count: 1116
[2017-09-01 22:18:38] |
User735389 - Posts: 189 |
For a chart window, I don't want to show the actual chart (graph region 0), only the other graph regions underneath. Is there a way to do this? Whether through explicitly hiding the chart or resizing the bottom graph.
[2017-09-04 18:42:36] |
You could set the Chart >> Graph Draw Type to Blank.
