Date/Time: Wed, 15 Jan 2025 17:45:41 +0000
Chart trade window can not be moved around after updating to V1605
View Count: 748
[2017-09-01 14:32:47] |
superdoug3 - Posts: 40 |
I would like to manually move Chart Trade Window about on my chart, it is currently fixed on my chart I have tried Chart >> Chart Settings >> Advanced Settings tab >> Attach Trade Window to Right Side - this just moved it to bottom of my chart |
[2017-09-01 16:31:33] |
You need to detach it by selecting Trade >> Attach Trade Window to Chart. We do not see how it could be at the bottom of the chart. Either the left or the right if it is attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
