Date/Time: Tue, 22 Apr 2025 18:30:43 +0000
Charting the difference between yesterdays close and the current price
View Count: 1731
[2017-09-01 12:22:04]
User771280 - Posts: 4
I'm plotting the difference between yesterdays close and the current price of the ES.
I'm using:
1. One main 5 minute ES chart that is set to start: 15:30 stop 15:14:59
2. Added Study/Price Overlay for another daily ES chart that is set to start: 8:30 stop 15:14:59
3. Added study subgraph subtract/difference:
Input study #1 = main5 minute ES chart using the Last option
Input study #2 = main5 minute ES chart using the Last option
Study 2 subgraph offset = 1
Draw zeros = yes
Perform subtract with zero value = yes
Problem:
The study subgraph subtract/difference doesn't look at the current last daily bar (item #2) correctly throughout the trading session.
Normal output currently:
During the regular trading of 8:30 - 15:14:59 the plot has the correct value, looks at the last daily bar which is 1 day.
During the after hours trading of 15:30 - 8:29:59 the plot has the incorrect value...it still uses 2 days prior instead of 1 day. I can change the "Study 2 subgraph offset = 1" to "Study 2 subgraph offset = 0" and I get the correct value.
[2017-09-01 12:24:24]
Sorry...mistake in the prior post! Please use this one.
I'm using:
Input study #1 = main 5 minute ES chart using the Last option
Input study #2 = main daily ES chart using the Last option
Draw zeros = yes
Problem:
[2017-09-01 18:41:38]
We have prepared a Study Collection to accomplish what you want:
http://www.sierrachart.com/image.php?Image=1504290339783.png
It is attached.
Here are the instructions to use it:
http://www.sierrachart.com/index.php?page=doc/StudyCollections.html#UsingStudyCollectionProvidedBySierraChartSupport
Also you have the ability to edit a post by clicking the "Edit" link at the lower right of the post.
Date Time Of Last Edit: 2023-03-20 21:01:28
[2017-09-07 12:49:53]
This is what I want to do:
https://imgur.com/a/uSWVv
Not sure how to adapt the stdycollt to make it work.
[2017-09-07 18:53:16]
When posting an image of a chart, always use this method here:
For the Daily OHLC study which displays the current price, set the study Input Graph Open and Close Historically to Yes.
Date Time Of Last Edit: 2017-09-07 18:54:38
[2023-03-18 17:54:21]
User708541 - Posts: 135
Support,
Two Things: Can you update this Study Collection so it is compatible with current version of SC? (Thank you)
Also, I want to have a Study that plots a 'cumulative' line for the difference between yesterday's (or prior bar's) close with today's (or current bar's) Open - on a cumulative basis. I'm wondering if the Study above is similar enough to be easily modified for what I'm looking for.
Thank you.
[2023-03-20 16:36:33]
John - SC Support - Posts: 39418
We have updated the Study Collection so it works with current releases. It is attached to this thread. Refer to the following for how to use it:
Use the Cumulative Sum of Study set to whatever it is you want to accumulate. Refer to the following:
[2023-03-20 17:27:18]
User90125 - Posts: 715
I only see the following: Attached On 2017-09-01 18:10:08 UTC - Size: 28 KB - 257 views
Is there a new collection attached somewhere? May want to remove the old one, if that's the case.
[2023-03-20 21:01:13]
Sorry, neglected to actually attach the file. Here is the updated one.
attachmentYesterdaysCloseTodaysCloseDifference.StdyCollct - Attached On 2023-03-20 21:01:04 UTC - Size: 48.19 KB - 213 views
