Date/Time: Wed, 15 Jan 2025 17:59:38 +0000
price projection problems
View Count: 805
[2017-09-01 11:46:04] |
User257062 - Posts: 2 |
I have successfully entered the parameters I use for fib extensions/price projections and saved them. However when I click on a price point its as if my mouse won't click or draw the extensions. In other words nothing happens when I go and click to draw the price points for the projection. My mouse is completely functional and this only occurs when trying to apply to the extensions/projections. The fib projections are the only tool I use to trade. So close yet so far!!
[2017-09-01 15:32:08] |
Confirm you actually have the correct tool selected. Refer to: Chart Drawing Tools: Selecting Drawing Tools The other possibility is possibly a Date-Time error in the chart. In this case, refer to: Out of Order Timestamps Detected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
