Date/Time: Wed, 15 Jan 2025 17:57:12 +0000
Symbol Lookup
View Count: 1526
[2017-09-01 10:02:23] |
jimskin - Posts: 127 |
Does SC have a symbol lookup auto-complete option? I tried the 'Find Symbol > Selected Symbol (Type symbol or select one from list above)' option but it simply opens a chart of whatever symbol you type in (if you enter a symbol that isn't available you get a blank chart). There's no auto-complete feature allowing you to search all the symbols. Also, is it possible to add a Symbol lookup input to the main menu rather than having to click the [FS] button? Thanks
[2017-09-01 18:18:18] |
There is no way to search among all symbols through the Find Symbol window. Auto complete is not supported either. You can search for symbols though on this page: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
