Date/Time: Wed, 15 Jan 2025 18:01:55 +0000
How do I know Im using Sierra data?
View Count: 784
[2017-09-01 10:02:15] |
grantx - Posts: 244 |
Sierra Chart Exchange Data Feed Help file says that I need to see the 'M' indicator. I dont see the M indicator. Ive followed all instructions in your help file to no avail. Also: Do I have to have the TWS software running at the same time as Sierra in order to trade with Interactive Brokers? |
[2017-09-01 14:15:44] |
You need to follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Do I have to have the TWS software running at the same time as Sierra in order to trade with Interactive Brokers? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
