Date/Time: Wed, 15 Jan 2025 18:05:18 +0000
Windows 10 recomendations
View Count: 1089
[2017-09-01 02:58:56] |
Willson - Posts: 176 |
My windows 7 compter is bad. Must replace with Win. 10 Professional. What is effect for SC users? What is guidance for best conversion? |
[2017-09-01 03:21:47] |
What is wrong with Windows 7? That is a good operating system. We recommend staying with that rather than using Windows 10. But if you need to use Windows 10, then that is fine as well. We are not aware of any problems with Sierra Chart running on Windows 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-01 12:58:40] |
User29926 - Posts: 92 |
I have SC on a win 7 and a win 10 workstations. It runs find on both. If your win7 pc is dieing, I suggest you backup your SC folder.. |
