Date/Time: Tue, 18 Feb 2025 21:59:35 +0000
possible to use excel wildcards in spreadsheet formulas?
View Count: 1546
[2013-09-04 16:22:38] |
4646ed - Posts: 230 |
if so, which ones. i tried ? and * but i just get the invalid formula dialogue.
[2013-09-04 18:08:25] |
We are not familiar with Excel wildcards. They are not supported.
[2013-09-04 20:52:09] |
i hope you change that with the new spreadsheets. they save alot of work and time.
