Date/Time: Sat, 26 Sep 2026 22:45:09 +0000
Market Data Connection login failed
View Count: 2174
| [2017-08-31 15:37:48] |
| User553682 - Posts: 9 |
I have still problems with the market data connection. Everything works perfect for one year and now I am not able to connect. I have already upload my Rithmic.log.OOO file. |
Attachment Deleted. Attachment Deleted. |
| [2017-08-31 16:06:46] |
We need to see the Sierra Chart Message Log. Not the Rithmic log file. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-08-31 16:21:28] |
Reading Internal Order ID file. | 2017-08-31 08:35:47 Reading Trade Orders file. | 2017-08-31 08:35:47 Reading Trade Positions file. | 2017-08-31 08:35:47 Listening on UDP port 22903. | 2017-08-31 08:35:47 Software version: 1605 | 2017-08-31 08:35:47 Enabled for: Advanced Features. | 2017-08-31 08:35:47 Enabled for: Advanced Features 2. | 2017-08-31 08:35:47 Enabled for: Sierra Chart Historical Data Service. | 2017-08-31 08:35:47 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-08-31 08:35:47 Current selected Data/Trading service: Rithmic Trading | 2017-08-31 08:35:47 Chart Update Interval: 500 | 2017-08-31 08:35:47 Data/Trade Service Settings automatically set. | 2017-08-31 08:35:47 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-08-31 08:35:47 2017-08-31 15:35:52 Local computer time | 2017-08-31 08:35:47 2017-08-31 13:35:52 Local computer time in UTC | 2017-08-31 08:35:47 2017-08-31 08:35:52 Local computer time in SC Time Zone | 2017-08-31 08:35:47 2017-08-31 13:35:47 Server time in UTC | 2017-08-31 08:35:47 Local computer UTC time and Server UTC time difference: 4 seconds. | 2017-08-31 08:35:47 Program path: C:\SierraChart\ | 2017-08-31 08:35:47 Data Files path: C:\SierraChart\Data\ | 2017-08-31 08:35:47 OS Version Number: 6.1 | 2017-08-31 08:35:47 Locale Setting: C | 2017-08-31 08:35:47 Rithmic Trading | Port for executable: 50167 | 2017-08-31 10:36:36 Listening socket (876), port 50167 | Closed. | 2017-08-31 10:36:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-08-31 10:36:36 Rithmic Trading | Bridge process is running. | 2017-08-31 10:36:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50167 | 2017-08-31 10:36:38 DTC Client (232) | Creating socket. | 2017-08-31 10:36:38 DTC Client (232) | Connecting to IP: 127.0.0.1. | 2017-08-31 10:36:38 Rithmic Trading | Connected to server. | 2017-08-31 10:36:38 Rithmic Trading | Starting socket receive thread. | 2017-08-31 10:36:38 Rithmic Trading | Sending Encoding Request to server | 2017-08-31 10:36:38 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-08-31 10:36:38 Rithmic Trading | Sending logon request message. | 2017-08-31 10:36:38 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-08-31 10:36:38 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-08-31 10:36:38 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-08-31 10:36:38 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-08-31 10:36:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-08-31 10:36:39 Rithmic Trading | Received logon response. | 2017-08-31 10:36:39 Rithmic Trading | Server Name: DTC Bridge. | 2017-08-31 10:36:39 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-08-31 10:36:39 Rithmic Trading | Logon error received from server | 2017-08-31 10:36:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-08-31 10:36:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-08-31 10:36:39 DTC Client (232) | Initiating close of socket by core. | 2017-08-31 10:36:39 Rithmic Trading | Disconnected. | 2017-08-31 10:36:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-08-31 10:36:39 DTC Client (232) | Shutdown started. Waiting for graceful close. | 2017-08-31 10:36:39 DTC Client (232) | Socket gracefully closed by remote side. | 2017-08-31 10:36:39 DTC Client (232) | Closed. | 2017-08-31 10:36:39 File >> Disconnect selected. | 2017-08-31 10:38:32 Rithmic Trading | Disconnected. | 2017-08-31 10:38:32 Date Time Of Last Edit: 2017-08-31 17:09:42
| [2017-08-31 17:10:35] |
This is the relevant message: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-08-31 10:36:39 Follow the instructions here to resolve this: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-31 17:11:14
| [2017-08-31 18:26:54] |
I try all the steps from the instructions with you send me in the link. Nothing works. Last step is, that I will send you the Rithmic log file and you will send it to Rithmic to solve this problem. So I attached the Rithmic log file. |
| [2017-08-31 18:30:53] |
OK we understand. We will have to contact Rithmic about this.
| [2017-09-01 03:50:40] |
We have sent the relevant portion of the log file to Rithmic. You should also contact your broker about this as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-01 03:50:49
| [2017-09-04 13:26:38] |
Have you got any response from Rithmic about this problem? The situation is still the same, it doesn´t work.
| [2017-09-04 13:27:10] |
Reading Internal Order ID file. | 2017-09-04 08:23:04 Reading Trade Orders file. | 2017-09-04 08:23:04 Reading Trade Positions file. | 2017-09-04 08:23:04 Listening on UDP port 22903. | 2017-09-04 08:23:04 Software version: 1605 | 2017-09-04 08:23:04 Enabled for: Advanced Features. | 2017-09-04 08:23:04 Enabled for: Advanced Features 2. | 2017-09-04 08:23:04 Enabled for: Sierra Chart Historical Data Service. | 2017-09-04 08:23:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-09-04 08:23:04 Current selected Data/Trading service: Rithmic Trading | 2017-09-04 08:23:04 Chart Update Interval: 500 | 2017-09-04 08:23:04 Data/Trade Service Settings automatically set. | 2017-09-04 08:23:04 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-09-04 08:23:04 2017-09-04 15:23:09 Local computer time | 2017-09-04 08:23:04 2017-09-04 13:23:09 Local computer time in UTC | 2017-09-04 08:23:04 2017-09-04 08:23:09 Local computer time in SC Time Zone | 2017-09-04 08:23:04 2017-09-04 13:23:00 Server time in UTC | 2017-09-04 08:23:04 Local computer UTC time and Server UTC time difference: 7 seconds. | 2017-09-04 08:23:04 Program path: C:\SierraChart\ | 2017-09-04 08:23:04 Data Files path: C:\SierraChart\Data\ | 2017-09-04 08:23:04 OS Version Number: 6.1 | 2017-09-04 08:23:04 Locale Setting: C | 2017-09-04 08:23:04 Checking for new symbol settings for service code rim | 2017-09-04 08:23:04 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-09-04 08:23:04 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-09-04 08:23:04 Symbol settings are up-to-date for rim | 2017-09-04 08:23:10 Received 5 login tokens. | 2017-09-04 08:23:10 Files to Open on Start up | Opening file: Chartbook1.cht | 2017-09-04 08:23:12 NQZ6-CME 1 Min #2 | Reloading chart. | 2017-09-04 08:23:12 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ6-CME | 2017-09-04 08:23:13 Intraday data recording state for symbol NQZ6-CME is set to download 'Pending'. | 2017-09-04 08:23:13 HD Request # 2 | Downloading Intraday chart data for NQZ6-CME to the file NQZ6-CME.scid. Service: cme | 2017-09-04 08:23:13 HD Request # 2 | Download start date-time: 2016-12-16 08:29:59.000 | 2017-09-04 08:23:13 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2017-09-04 08:23:13 Socket (5) | Creating socket. | 2017-09-04 08:23:13 Socket (5) | Connecting to IP: 8.18.161.133. | 2017-09-04 08:23:13 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-09-04 08:23:13 HD Request # 2 | Sending historical data logon request message. | 2017-09-04 08:23:13 HD Request # 2 | Requesting Intraday data. Start date-time: 2016-12-16 08:29:59. Record interval: 0. Symbol: NQZ16 | 2017-09-04 08:23:13 HD Request # 2 | Decompressing data. | 2017-09-04 08:23:13 HD Request # 2 | Receiving Intraday data for NQZ6-CME starting at 2016-12-16 08:29:59 | 2017-09-04 08:23:13 Socket (5) | Initiating close of socket by core. | 2017-09-04 08:23:13 Socket (5) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:23:13 Socket (5) | Socket gracefully closed by remote side. | 2017-09-04 08:23:13 Socket (5) | Closed. | 2017-09-04 08:23:13 HD Request # 2 | Historical data for NQZ6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-09-04 08:23:13 Historical data download thread signaled to stop. | 2017-09-04 08:23:13 HD Request # 2 | Received 1 record from 2016-12-16 08:29:59 to 2016-12-16 08:29:59 (0.0 seconds) and wrote 0 records for NQZ6-CME | 2017-09-04 08:23:13 HD Request # 2 | Intraday download COMPLETE for NQZ6-CME. Completion time: 0s. Unique request ID: 1 | 2017-09-04 08:23:13 Removed historical data download ID 1 | 2017-09-04 08:23:13 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2017-09-04 08:23:13 Rithmic Trading | Port for executable: 52420 | 2017-09-04 08:23:14 Listening socket (848), port 52420 | Closed. | 2017-09-04 08:23:14 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:14 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-04 08:23:15 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-09-04 08:23:15 Rithmic Trading | Bridge process is running. | 2017-09-04 08:23:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52420 | 2017-09-04 08:23:16 DTC Client (6) | Creating socket. | 2017-09-04 08:23:16 DTC Client (6) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:16 Rithmic Trading | Connected to server. | 2017-09-04 08:23:16 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:23:16 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:23:16 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:23:16 Rithmic Trading | Sending logon request message. | 2017-09-04 08:23:16 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:23:16 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:23:16 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:23:16 + Finished LoadSingleIntradayFile | 2017-09-04 08:23:17 + OnThreadComplete. | 2017-09-04 08:23:17 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:23:18 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:23:18 Rithmic Trading | Received logon response. | 2017-09-04 08:23:18 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:23:18 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:23:18 Rithmic Trading | Logon error received from server | 2017-09-04 08:23:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:18 DTC Client (6) | Initiating close of socket by core. | 2017-09-04 08:23:18 Rithmic Trading | Disconnected. | 2017-09-04 08:23:18 DTC Client (6) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:23:18 DTC Client (6) | Socket gracefully closed by remote side. | 2017-09-04 08:23:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:18 DTC Client (6) | Closed. | 2017-09-04 08:23:18 Rithmic Trading | Port for executable: 52431 | 2017-09-04 08:23:20 Listening socket (844), port 52431 | Closed. | 2017-09-04 08:23:20 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:20 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:22 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52431 | 2017-09-04 08:23:22 DTC Client (7) | Creating socket. | 2017-09-04 08:23:22 DTC Client (7) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:22 DTC Client (7) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:23 * DTC Client (7) | Initiating close of socket by core. | 2017-09-04 08:23:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:23 DTC Client (7) | Closed. | 2017-09-04 08:23:23 Rithmic Trading | Disconnected. | 2017-09-04 08:23:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:23 Rithmic Trading | Port for executable: 52434 | 2017-09-04 08:23:25 Listening socket (848), port 52434 | Closed. | 2017-09-04 08:23:25 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:25 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:27 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52434 | 2017-09-04 08:23:27 DTC Client (8) | Creating socket. | 2017-09-04 08:23:27 DTC Client (8) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:27 DTC Client (8) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:28 * DTC Client (8) | Initiating close of socket by core. | 2017-09-04 08:23:28 DTC Client (8) | Closed. | 2017-09-04 08:23:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:28 Rithmic Trading | Disconnected. | 2017-09-04 08:23:28 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:28 Rithmic Trading | Port for executable: 52438 | 2017-09-04 08:23:30 Listening socket (844), port 52438 | Closed. | 2017-09-04 08:23:30 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:30 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:32 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52438 | 2017-09-04 08:23:32 DTC Client (9) | Creating socket. | 2017-09-04 08:23:32 DTC Client (9) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:32 DTC Client (9) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:33 * DTC Client (9) | Initiating close of socket by core. | 2017-09-04 08:23:33 DTC Client (9) | Closed. | 2017-09-04 08:23:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:33 Rithmic Trading | Disconnected. | 2017-09-04 08:23:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:33 Rithmic Trading | Port for executable: 52442 | 2017-09-04 08:23:35 Listening socket (844), port 52442 | Closed. | 2017-09-04 08:23:35 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:35 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52442 | 2017-09-04 08:23:37 DTC Client (10) | Creating socket. | 2017-09-04 08:23:37 DTC Client (10) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:37 DTC Client (10) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:38 * DTC Client (10) | Initiating close of socket by core. | 2017-09-04 08:23:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:38 DTC Client (10) | Closed. | 2017-09-04 08:23:38 Rithmic Trading | Disconnected. | 2017-09-04 08:23:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:38 Rithmic Trading | Port for executable: 52444 | 2017-09-04 08:23:40 Listening socket (868), port 52444 | Closed. | 2017-09-04 08:23:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:40 Rithmic Trading | Bridge process is running. | 2017-09-04 08:23:42 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52444 | 2017-09-04 08:23:42 DTC Client (11) | Creating socket. | 2017-09-04 08:23:42 DTC Client (11) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:42 Rithmic Trading | Connected to server. | 2017-09-04 08:23:42 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:23:42 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:23:42 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:23:42 Rithmic Trading | Sending logon request message. | 2017-09-04 08:23:42 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:23:42 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:23:42 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:23:42 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:23:43 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:23:43 Rithmic Trading | Received logon response. | 2017-09-04 08:23:43 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:23:43 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:23:43 Rithmic Trading | Logon error received from server | 2017-09-04 08:23:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:43 DTC Client (11) | Initiating close of socket by core. | 2017-09-04 08:23:43 DTC Client (11) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:23:43 DTC Client (11) | Socket gracefully closed by remote side. | 2017-09-04 08:23:43 DTC Client (11) | Closed. | 2017-09-04 08:23:43 Rithmic Trading | Disconnected. | 2017-09-04 08:23:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:43 Rithmic Trading | Port for executable: 52454 | 2017-09-04 08:23:45 Listening socket (888), port 52454 | Closed. | 2017-09-04 08:23:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:45 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:47 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52454 | 2017-09-04 08:23:47 DTC Client (12) | Creating socket. | 2017-09-04 08:23:47 DTC Client (12) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:47 DTC Client (12) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:48 * DTC Client (12) | Initiating close of socket by core. | 2017-09-04 08:23:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:48 DTC Client (12) | Closed. | 2017-09-04 08:23:48 Rithmic Trading | Disconnected. | 2017-09-04 08:23:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:48 Rithmic Trading | Port for executable: 52456 | 2017-09-04 08:23:50 Listening socket (868), port 52456 | Closed. | 2017-09-04 08:23:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:50 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:52 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52456 | 2017-09-04 08:23:52 DTC Client (13) | Creating socket. | 2017-09-04 08:23:52 DTC Client (13) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:52 DTC Client (13) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:53 * DTC Client (13) | Initiating close of socket by core. | 2017-09-04 08:23:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:53 DTC Client (13) | Closed. | 2017-09-04 08:23:53 Rithmic Trading | Disconnected. | 2017-09-04 08:23:53 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:53 Rithmic Trading | Port for executable: 52460 | 2017-09-04 08:23:55 Listening socket (888), port 52460 | Closed. | 2017-09-04 08:23:55 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:23:55 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:23:57 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52460 | 2017-09-04 08:23:57 DTC Client (14) | Creating socket. | 2017-09-04 08:23:57 DTC Client (14) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:23:57 DTC Client (14) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:23:58 * DTC Client (14) | Initiating close of socket by core. | 2017-09-04 08:23:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:23:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:58 DTC Client (14) | Closed. | 2017-09-04 08:23:58 Rithmic Trading | Disconnected. | 2017-09-04 08:23:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:23:58 Rithmic Trading | Port for executable: 52462 | 2017-09-04 08:24:00 Listening socket (868), port 52462 | Closed. | 2017-09-04 08:24:00 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:00 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52462 | 2017-09-04 08:24:02 DTC Client (15) | Creating socket. | 2017-09-04 08:24:02 DTC Client (15) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:02 DTC Client (15) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:03 * DTC Client (15) | Initiating close of socket by core. | 2017-09-04 08:24:03 DTC Client (15) | Closed. | 2017-09-04 08:24:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:03 Rithmic Trading | Disconnected. | 2017-09-04 08:24:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:03 Rithmic Trading | Port for executable: 52470 | 2017-09-04 08:24:05 Listening socket (332), port 52470 | Closed. | 2017-09-04 08:24:05 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:05 Rithmic Trading | Bridge process is running. | 2017-09-04 08:24:07 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52470 | 2017-09-04 08:24:07 DTC Client (16) | Creating socket. | 2017-09-04 08:24:07 DTC Client (16) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:07 Rithmic Trading | Connected to server. | 2017-09-04 08:24:07 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:24:07 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:24:07 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:24:07 Rithmic Trading | Sending logon request message. | 2017-09-04 08:24:07 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:24:07 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:24:07 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:24:07 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:24:09 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:24:09 Rithmic Trading | Received logon response. | 2017-09-04 08:24:09 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:24:09 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:24:09 Rithmic Trading | Logon error received from server | 2017-09-04 08:24:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:09 DTC Client (16) | Initiating close of socket by core. | 2017-09-04 08:24:09 Rithmic Trading | Disconnected. | 2017-09-04 08:24:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:09 DTC Client (16) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:24:09 DTC Client (16) | Socket gracefully closed by remote side. | 2017-09-04 08:24:09 DTC Client (16) | Closed. | 2017-09-04 08:24:09 Rithmic Trading | Port for executable: 52480 | 2017-09-04 08:24:11 Listening socket (332), port 52480 | Closed. | 2017-09-04 08:24:11 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:11 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52480 | 2017-09-04 08:24:13 DTC Client (17) | Creating socket. | 2017-09-04 08:24:13 DTC Client (17) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:13 DTC Client (17) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:14 * DTC Client (17) | Initiating close of socket by core. | 2017-09-04 08:24:14 DTC Client (17) | Closed. | 2017-09-04 08:24:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:14 Rithmic Trading | Disconnected. | 2017-09-04 08:24:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:14 Rithmic Trading | Port for executable: 52487 | 2017-09-04 08:24:16 Listening socket (664), port 52487 | Closed. | 2017-09-04 08:24:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:16 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52487 | 2017-09-04 08:24:18 DTC Client (18) | Creating socket. | 2017-09-04 08:24:18 DTC Client (18) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:18 DTC Client (18) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:19 * DTC Client (18) | Initiating close of socket by core. | 2017-09-04 08:24:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:19 DTC Client (18) | Closed. | 2017-09-04 08:24:19 Rithmic Trading | Disconnected. | 2017-09-04 08:24:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:19 Rithmic Trading | Port for executable: 52492 | 2017-09-04 08:24:21 Listening socket (332), port 52492 | Closed. | 2017-09-04 08:24:21 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:21 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52492 | 2017-09-04 08:24:23 DTC Client (19) | Creating socket. | 2017-09-04 08:24:23 DTC Client (19) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:23 DTC Client (19) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:24 * DTC Client (19) | Initiating close of socket by core. | 2017-09-04 08:24:24 DTC Client (19) | Closed. | 2017-09-04 08:24:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:24 Rithmic Trading | Disconnected. | 2017-09-04 08:24:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:24 Rithmic Trading | Port for executable: 52495 | 2017-09-04 08:24:26 Listening socket (660), port 52495 | Closed. | 2017-09-04 08:24:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:26 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52495 | 2017-09-04 08:24:28 DTC Client (20) | Creating socket. | 2017-09-04 08:24:28 DTC Client (20) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:28 DTC Client (20) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:29 * DTC Client (20) | Initiating close of socket by core. | 2017-09-04 08:24:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:29 DTC Client (20) | Closed. | 2017-09-04 08:24:29 Rithmic Trading | Disconnected. | 2017-09-04 08:24:29 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:29 Rithmic Trading | Port for executable: 52503 | 2017-09-04 08:24:31 Listening socket (332), port 52503 | Closed. | 2017-09-04 08:24:31 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:31 Rithmic Trading | Bridge process is running. | 2017-09-04 08:24:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52503 | 2017-09-04 08:24:33 DTC Client (21) | Creating socket. | 2017-09-04 08:24:33 DTC Client (21) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:33 Rithmic Trading | Connected to server. | 2017-09-04 08:24:33 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:24:33 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:24:33 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:24:33 Rithmic Trading | Sending logon request message. | 2017-09-04 08:24:33 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:24:33 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:24:33 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:24:33 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:24:34 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:24:35 Rithmic Trading | Received logon response. | 2017-09-04 08:24:35 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:24:35 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:24:35 Rithmic Trading | Logon error received from server | 2017-09-04 08:24:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:35 DTC Client (21) | Initiating close of socket by core. | 2017-09-04 08:24:35 Rithmic Trading | Disconnected. | 2017-09-04 08:24:35 DTC Client (21) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:24:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:35 DTC Client (21) | Socket gracefully closed by remote side. | 2017-09-04 08:24:35 DTC Client (21) | Closed. | 2017-09-04 08:24:35 Rithmic Trading | Port for executable: 52514 | 2017-09-04 08:24:37 Listening socket (332), port 52514 | Closed. | 2017-09-04 08:24:37 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:37 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52514 | 2017-09-04 08:24:39 DTC Client (22) | Creating socket. | 2017-09-04 08:24:39 DTC Client (22) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:39 DTC Client (22) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:40 * DTC Client (22) | Initiating close of socket by core. | 2017-09-04 08:24:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:40 DTC Client (22) | Closed. | 2017-09-04 08:24:40 Rithmic Trading | Disconnected. | 2017-09-04 08:24:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:40 Rithmic Trading | Port for executable: 52517 | 2017-09-04 08:24:42 Listening socket (848), port 52517 | Closed. | 2017-09-04 08:24:42 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:42 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52517 | 2017-09-04 08:24:44 DTC Client (23) | Creating socket. | 2017-09-04 08:24:44 DTC Client (23) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:44 DTC Client (23) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:45 * DTC Client (23) | Initiating close of socket by core. | 2017-09-04 08:24:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:45 DTC Client (23) | Closed. | 2017-09-04 08:24:45 Rithmic Trading | Disconnected. | 2017-09-04 08:24:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:45 Rithmic Trading | Port for executable: 52519 | 2017-09-04 08:24:47 Listening socket (676), port 52519 | Closed. | 2017-09-04 08:24:47 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:47 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52519 | 2017-09-04 08:24:49 DTC Client (24) | Creating socket. | 2017-09-04 08:24:49 DTC Client (24) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:49 DTC Client (24) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:50 * DTC Client (24) | Initiating close of socket by core. | 2017-09-04 08:24:50 DTC Client (24) | Closed. | 2017-09-04 08:24:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:50 Rithmic Trading | Disconnected. | 2017-09-04 08:24:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:50 Rithmic Trading | Port for executable: 52521 | 2017-09-04 08:24:51 Listening socket (332), port 52521 | Closed. | 2017-09-04 08:24:51 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:51 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:24:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52521 | 2017-09-04 08:24:54 DTC Client (25) | Creating socket. | 2017-09-04 08:24:54 DTC Client (25) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:54 DTC Client (25) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:24:55 * DTC Client (25) | Initiating close of socket by core. | 2017-09-04 08:24:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:24:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:55 DTC Client (25) | Closed. | 2017-09-04 08:24:55 Rithmic Trading | Disconnected. | 2017-09-04 08:24:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:24:55 Rithmic Trading | Port for executable: 52523 | 2017-09-04 08:24:57 Listening socket (676), port 52523 | Closed. | 2017-09-04 08:24:57 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:24:57 Rithmic Trading | Bridge process is running. | 2017-09-04 08:24:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52523 | 2017-09-04 08:24:59 DTC Client (26) | Creating socket. | 2017-09-04 08:24:59 DTC Client (26) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:24:59 Rithmic Trading | Connected to server. | 2017-09-04 08:24:59 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:24:59 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:24:59 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:24:59 Rithmic Trading | Sending logon request message. | 2017-09-04 08:24:59 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:24:59 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:24:59 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:24:59 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:25:00 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:25:00 Rithmic Trading | Received logon response. | 2017-09-04 08:25:00 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:25:00 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:25:00 Rithmic Trading | Logon error received from server | 2017-09-04 08:25:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:25:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:00 DTC Client (26) | Initiating close of socket by core. | 2017-09-04 08:25:00 Rithmic Trading | Disconnected. | 2017-09-04 08:25:00 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:00 DTC Client (26) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:25:00 DTC Client (26) | Socket gracefully closed by remote side. | 2017-09-04 08:25:00 DTC Client (26) | Closed. | 2017-09-04 08:25:00 Rithmic Trading | Port for executable: 52533 | 2017-09-04 08:25:02 Listening socket (676), port 52533 | Closed. | 2017-09-04 08:25:02 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:25:02 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:25:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52533 | 2017-09-04 08:25:04 DTC Client (27) | Creating socket. | 2017-09-04 08:25:04 DTC Client (27) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:25:04 DTC Client (27) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:25:05 * DTC Client (27) | Initiating close of socket by core. | 2017-09-04 08:25:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:25:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:05 DTC Client (27) | Closed. | 2017-09-04 08:25:05 Rithmic Trading | Disconnected. | 2017-09-04 08:25:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:05 Rithmic Trading | Port for executable: 52536 | 2017-09-04 08:25:07 Listening socket (648), port 52536 | Closed. | 2017-09-04 08:25:07 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:25:07 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:25:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52536 | 2017-09-04 08:25:09 DTC Client (28) | Creating socket. | 2017-09-04 08:25:09 DTC Client (28) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:25:09 DTC Client (28) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:25:10 * DTC Client (28) | Initiating close of socket by core. | 2017-09-04 08:25:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:25:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:10 DTC Client (28) | Closed. | 2017-09-04 08:25:10 Rithmic Trading | Disconnected. | 2017-09-04 08:25:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:25:10 File >> Disconnect selected. | 2017-09-04 08:25:11 Rithmic Trading | Disconnected. | 2017-09-04 08:25:11 Rithmic Trading | Port for executable: 52547 | 2017-09-04 08:26:52 Listening socket (676), port 52547 | Closed. | 2017-09-04 08:26:52 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:26:52 Rithmic Trading | Bridge process is running. | 2017-09-04 08:26:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52547 | 2017-09-04 08:26:54 DTC Client (29) | Creating socket. | 2017-09-04 08:26:54 DTC Client (29) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:26:54 Rithmic Trading | Connected to server. | 2017-09-04 08:26:54 Rithmic Trading | Starting socket receive thread. | 2017-09-04 08:26:54 Rithmic Trading | Sending Encoding Request to server | 2017-09-04 08:26:54 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-09-04 08:26:54 Rithmic Trading | Sending logon request message. | 2017-09-04 08:26:54 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-09-04 08:26:54 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-09-04 08:26:54 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-09-04 08:26:54 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-09-04 08:26:55 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-09-04 08:26:55 Rithmic Trading | Received logon response. | 2017-09-04 08:26:55 Rithmic Trading | Server Name: DTC Bridge. | 2017-09-04 08:26:55 Rithmic Trading | Server protocol version: 7. Client protocol version: 8 | 2017-09-04 08:26:55 Rithmic Trading | Logon error received from server | 2017-09-04 08:26:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:26:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:26:55 DTC Client (29) | Initiating close of socket by core. | 2017-09-04 08:26:55 Rithmic Trading | Disconnected. | 2017-09-04 08:26:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:26:55 DTC Client (29) | Shutdown started. Waiting for graceful close. | 2017-09-04 08:26:55 DTC Client (29) | Socket gracefully closed by remote side. | 2017-09-04 08:26:55 DTC Client (29) | Closed. | 2017-09-04 08:26:55 Rithmic Trading | Port for executable: 52557 | 2017-09-04 08:26:57 Listening socket (332), port 52557 | Closed. | 2017-09-04 08:26:57 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:26:57 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:26:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52557 | 2017-09-04 08:26:59 DTC Client (30) | Creating socket. | 2017-09-04 08:26:59 DTC Client (30) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:26:59 DTC Client (30) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:27:00 * DTC Client (30) | Initiating close of socket by core. | 2017-09-04 08:27:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:27:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:27:00 DTC Client (30) | Closed. | 2017-09-04 08:27:00 Rithmic Trading | Disconnected. | 2017-09-04 08:27:00 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:27:00 Rithmic Trading | Port for executable: 52559 | 2017-09-04 08:27:02 Listening socket (676), port 52559 | Closed. | 2017-09-04 08:27:02 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:27:02 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:27:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52559 | 2017-09-04 08:27:04 DTC Client (31) | Creating socket. | 2017-09-04 08:27:04 DTC Client (31) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:27:04 DTC Client (31) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2017-09-04 08:27:05 * DTC Client (31) | Initiating close of socket by core. | 2017-09-04 08:27:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-09-04 08:27:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:27:05 DTC Client (31) | Closed. | 2017-09-04 08:27:05 Rithmic Trading | Disconnected. | 2017-09-04 08:27:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-09-04 08:27:05 Rithmic Trading | Port for executable: 52564 | 2017-09-04 08:27:07 Listening socket (332), port 52564 | Closed. | 2017-09-04 08:27:07 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-09-04 08:27:07 Rithmic Trading | Bridge process is not running! | 2017-09-04 08:27:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52564 | 2017-09-04 08:27:09 DTC Client (32) | Creating socket. | 2017-09-04 08:27:09 DTC Client (32) | Connecting to IP: 127.0.0.1. | 2017-09-04 08:27:09 File >> Disconnect selected. | 2017-09-04 08:27:09 DTC Client (32) | Initiating close of socket by core. | 2017-09-04 08:27:09 Rithmic Trading | Disconnected. | 2017-09-04 08:27:09 DTC Client (32) | Closed. | 2017-09-04 08:27:09 |
| [2017-09-05 18:59:14] |
Have you got any response from Rithmic about this problem? The situation is still the same, it doesn´t work. I have already contact my broker.
| [2017-09-05 19:09:52] |
No we got no response from Rithmic and we really recommend you get off Rithmic and over to CQG. Who is your broker? This whole permission denied problem is quite ridiculous to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-09-05 19:12:15] |
Here is the information we have about the Permission Denied error: Rithmic Trading Platform Service: Permission Denied Resolution Procedure As long as you understand the information given there and you follow through that information and you still cannot resolve the problem we recommend not using Rithmic. It is not worth this kind of problem. This problem should never have been going on so long. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-05 19:12:50
| [2017-09-06 13:41:49] |
Have the CQG tick by tick data? My broker is AMP. |
| [2017-09-06 15:50:32] |
Definitely use CQG. Tell your broker that is what you want to use. Do not waste time with Rithmic any longer. Yes there is tick by tick data when using CQG. Rithmic should only be used if there is no other choice but to use that based upon the broker and situation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-06 15:51:22
