Date/Time: Mon, 20 Jan 2025 11:29:03 +0000
Mute Individual Chartbook
View Count: 1317
[2017-08-31 14:03:40] |
User104854 - Posts: 457 |
Is there a way to mute an individual chartbook when I have more than 1 open? I have audio alerts set and there are times when I want to focus on just one market and would prefer to not have to close the other chartbooks. If this is not currently available would you consider adding this feature? Thanks.
[2017-09-02 03:24:11] |
Did you receive this?
[2017-09-05 13:45:14] |
Can I get a response on this question please?
[2018-06-10 14:34:47] |
TSiSVT - Posts: 21 |
I would like this feature available as well.
[2018-06-11 17:06:13] |
This really is not easy add. It will have to be looked at later on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-11 17:06:23
[2018-06-12 08:15:49] |
samual sprat - Posts: 343 |
This would be a great feature I'd love to see it too
