Date/Time: Wed, 15 Jan 2025 18:05:58 +0000
Add 3M Chart button on Control Bar 1
View Count: 1008
[2017-08-31 12:45:29] |
User942178 - Posts: 25 |
How do I add a 3Minute button on my Control Bar 1? Thank you |
[2017-08-31 14:37:32] |
Refer to: Control Bar: Custom Buttons for Intraday Chart Bar Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
