Date/Time: Wed, 15 Jan 2025 17:52:00 +0000
Border around value for DRAWSTYLE_CUSTOM_VALUE_AT_Y
View Count: 1064
[2017-08-31 09:05:17]
@sstfrederik - Posts: 405
Is there any way to produce a border around a value plotted with DRAWSTYLE_CUSTOM_VALUE_AT_Y in ACSIL?
Can this be added to the drawstyle?
Many thanks in advance.
Frederik
[2017-08-31 14:18:22]
No, this is not supported and there are no plans for this.
[2017-08-31 14:36:01]
Any pointers on how accomplish the border as seen on the attached image?
imageIMG_1711.PNG / V - Attached On 2017-08-31 14:34:47 UTC - Size: 1.36 MB - 347 views
[2017-09-01 03:30:38]
OK we see what you want. We will look into this. We will need to create a new draw style for that.
[2017-09-02 17:45:05]
Maybe adding sc.CombinedForegroundBackgroundColorRef() with using the sc.Subgraph[].DataColor[] array is quicker to implement? Would be great to distinguish values when using this drawstyle other than primary color.
Thanks.
[2017-09-02 20:38:54]
With the new Subgraph Draw Style the border around the text will be the same as the text color itself.
And the color can be controlled with sc.Subgraph[].DataColor[].
Date Time Of Last Edit: 2017-09-02 20:39:02
