Date/Time: Wed, 15 Jan 2025 18:01:23 +0000
Font Change in activity log
View Count: 1111
[2017-08-31 04:46:07] |
User806639 - Posts: 32 |
How do I change the Font and color of the text in the Activity log. I would like larger font and the positive results to be Green and the Negative results to be Red. Thank you |
[2017-08-31 14:19:25] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#SettingTheBackgroundColorAndTextColorForTextOnlyWindows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
