Date/Time: Wed, 15 Jan 2025 17:51:01 +0000
different DOM
View Count: 1027
[2017-08-30 22:01:08] |
Mohd S - Posts: 4 |
im using trial for now.. why my DOM is different with other people DOM?the first 1 pic is mine and 2nd pic is other people DOM.. how to do like the 2nd pic? |
Screenshot_10.png / V - Attached On 2017-08-30 22:00:26 UTC - Size: 19.93 KB - 292 views Screenshot_12.png / V - Attached On 2017-08-30 22:00:36 UTC - Size: 76.2 KB - 318 views |
[2017-08-31 04:15:13] |
You need to customize the Chart/Trade DOM columns to match. Here are instructions: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns The documentation specifically explains how to put the market depth quantities within the buy and sell columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-31 06:57:14] |
Mohd S - Posts: 4 |
still depth data do not show up..data come just number 1 only..
Screenshot_14.png / V - Attached On 2017-08-31 06:55:41 UTC - Size: 52.31 KB - 273 views |
[2017-08-31 08:58:04] |
Mohd S - Posts: 4 |
im using free trial and so confius why depth is blank..no data come like other DOM..and no data on open market depth window
Date Time Of Last Edit: 2017-08-31 09:06:14
Screenshot_1.png / V - Attached On 2017-08-31 08:56:13 UTC - Size: 26.25 KB - 271 views Screenshot_2.png / V - Attached On 2017-08-31 08:56:21 UTC - Size: 29.91 KB - 279 views Screenshot_4.png / V - Attached On 2017-08-31 08:56:46 UTC - Size: 20.52 KB - 258 views Screenshot_5.png / V - Attached On 2017-08-31 08:56:55 UTC - Size: 42.74 KB - 318 views Screenshot_6.png / V - Attached On 2017-08-31 08:57:03 UTC - Size: 28.72 KB - 264 views Screenshot_3.png / V - Attached On 2017-08-31 08:57:12 UTC - Size: 39.46 KB - 286 views Screenshot_7.png / V - Attached On 2017-08-31 09:06:10 UTC - Size: 9.38 KB - 270 views |
[2017-08-31 11:03:10] |
The cash Forex symbols do not provide any market depth data.
[2017-08-31 12:27:16] |
Mohd S - Posts: 4 |
how about CFD?its same..i think all symbol i try but have no data from depth..
[2017-08-31 14:14:41] |
The CFD symbols from the Sierra Chart Real-time and Historical Forex/CFD Data feed do not provide market depth data either.
