Date/Time: Wed, 22 Jan 2025 00:31:13 +0000
Different Color Bar based on different volume sizes.
View Count: 2562
[2017-08-30 09:25:58] |
User258883 - Posts: 1 |
For example in a 1 minute chart, I want to color the bar blue if the corresponding volume is below 100, yellow if the volume is between 100 and 200, Orange if the volume for that bar exceed 200. Is that possible ? |
[2017-08-30 11:06:09] |
TechTrader - Posts: 116 |
You could use a Spreadsheet Study. An example is below. Copy the two files to your Sierra Data folder. Apply the study 'Volume Colour Bars' to a chart. |
Volume Colour Bars.scss - Attached On 2017-08-30 11:03:59 UTC - Size: 42.96 KB - 522 views Attachment Deleted. Volume Colour Bars.StdyCollct - Attached On 2017-08-30 11:04:55 UTC - Size: 9.41 KB - 496 views |
[2017-08-31 04:08:02] |
You need to use three instances of the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition These are the formulas for these: I want to color the bar blue if the corresponding volume is below 100: V < 100 yellow if the volume is between 100 and 200,: AND(V>=100,V<=200) Orange if the volume for that bar exceed 200.: V > 200 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-31 15:02:58] |
User747654 - Posts: 39 |
TechTrader, is there anyway to edit the bar preferences? I have downloaded the files I just need to edit those 100-300 values, Any way I can do that? Thanks |
