Date/Time: Wed, 15 Jan 2025 17:41:51 +0000
[Programming Help] - error whit custom studies ticksize
View Count: 1033
[2017-08-30 05:05:22] |
User634276 - Posts: 12 |
The error is: The indicator calcul right only when I set CHART>>CHART SETTING>>PRICE DISPLAY FORMAT=1 && TICK SIZE=1 if not set to 1 indicator show 0 all time how to fix it? thx Xavier Date Time Of Last Edit: 2017-08-30 05:16:41
Private File |
[2017-08-30 16:40:10] |
We really are not understanding this.
[2017-08-30 23:42:02] |
Something wrong whit : p_DepthBars->GetMaxBidQuantity( , ). This simple code do the same error it is my code, what is it? Date Time Of Last Edit: 2017-08-30 23:50:41
Private File |
[2017-09-01 18:55:20] |
The problem is you are not setting PriceTickIndex parameter properly. You need to use this function to determine it: ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars): PriceToTickIndex Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-01 18:55:39
