Date/Time: Wed, 15 Jan 2025 15:28:37 +0000
Do settings in TransActAT for LIFO/FIFO/Average-out have any effect on ACSIL orders?
View Count: 760
[2017-08-28 18:54:51] |
User875058 - Posts: 3 |
Hi, When using TransActAT I am intentionally using LIFO mode for some trades I place manually within TransActAT user interface. (I configure this in the TransActAT Properties window.) At other times, I execute trades using a custom study in ACSIL. When executing trades from ACSIL, does the FIFO/LIFO/average-out setting in TransActAT have any effect on how my trades are executed? Or does that setting ONLY have an effect on trades I place from within the TransActAT user interface? Thanks |
[2017-08-28 18:57:48] |
No, we do not see how that setting would have any effect upon execution in any case.
[2017-08-28 19:05:53] |
Thanks for clarifying. (I know that some TransActAT settings, such as the auto-bracket orders checkbox, DO affect trades made from ACSIL, so I just wanted to confirm). Thanks again. |
