Date/Time: Wed, 15 Jan 2025 15:20:59 +0000
1603 version couldn't connect
View Count: 786
[2017-08-28 15:20:22] |
User99934 - Posts: 227 |
1603 version couldn't connect so I rolled back to 1601.
[2017-08-28 15:38:48] |
Connections to CTS using DTC and LMAX are not supported at this time using the latest prerelease. Please allow one or two more days.
