Date/Time: Wed, 15 Jan 2025 15:43:33 +0000
Verical Line Tool
View Count: 797
[2017-08-28 14:18:09]
Crtfyd - Posts: 281
Two things.
1-Not that important. FYI. The Vertical Line Tool for the last several versions. When I change the color from the default color I have, the line changes, but the time color stays the same.
2. I remember b4 you said the higher you put the study in your Studies Window, the higher the precedence will be for that study. I noticed recently you are noting in each study the precedence typically (normal, low, etc).
I noticed a Color Bar on Alert I have on a one minute chart takes several bars to show up, or I have to RAC (Reload all charts) for it to show up sooner. (Its on the session opening bar). A lot of studies on my chart.
By moving up the study to the top of the Studies Window, does that move up the precedence still?
Does the notation you added to the study regarding the precedence still apply? Just higher up within that group of precedence?
Thx
[2017-08-29 01:43:38]
1. This will be resolved in the next release.
2. This is explained here:
Chart Studies: Study Calculation Precedence And Related Issues
In general yes, but the documentation explains this much more thoroughly.
Date Time Of Last Edit: 2017-08-29 01:45:10
