Date/Time: Sun, 24 Nov 2024 01:40:58 +0000
version 1019 "SCFloatArrayRef" is not a recognized type
View Count: 1921
[2013-09-04 03:17:58] |
hairyMug - Posts: 31 |
after installing the latest version, SCFloatArrayRef is not recognised as a valid type in my Custom study...
[2013-09-04 04:26:02] |
This does not make sense. We see no problem with this. Make sure you are including an unmodified SierraChart.h file.
[2013-09-04 22:38:02] |
I completely agree, it does not make sendse so I un-installed and reinstalled 1018 and now it all works fine. So I tried it again and got many errors. So I tried the "CLR" version and attempted recompile and got the same results. I am back on 1018... One thing I failed to mention, I am using VS2010 Pro; maybe it is limited to that? |
[2013-09-04 22:57:33] |
Use prerelease version 1020. We do not see a reason why Visual C++ 2010 would be a problem. We use Visual Studio as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-05 01:42:27] |
I installed 1020... still cannot compile... I went back to 2016 and works fine... There are so many different compiler & linking settings, there must be some setting burried in there which is different in my setup. >> I am not familiar with what all these do as I mainly do "managed" code; VB.net & c#... |
[2013-09-05 17:08:40] |
Do you see SCFloatArrayRef defined in the SierraChart.H file you are using? Cannot think of any compiler and linker setting which would affect this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-09 01:12:30] |
I compared the previous "SierraChart.H" (v1016) with the current "SierraChart.H" (v1022). It seems that the main cause of the issue revolves around the inclusion of the "windows.h" file... #include <windows.h> //Main Windows SDK header file After removing it, I did get some expected compiler errors for "windows" functions which were not declared... I used the old "SierraChart.H" and my code compiled with no problems... I am not a C++ wizzard so I can't track down what the exact cause is but I hope this would give a clue... |
[2013-09-09 18:02:26] |
We are really not sure about this. We cannot reproduce the problem. We are using Visual C++ 2010.
[2013-09-13 03:04:12] |
I am also on Vs2010, Windows 7 (64 bit), 16 gig memory, Intel I7 processor... What OS are you on? |
[2013-09-13 03:08:58] |
Windows 7. We do not see the problem even when compiling with CLR. Show us the headers you are including in the CPP file you are compiling. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-13 10:51:10] |
Mystery Solved... This was caused by a function I created called "near"; When I renamed the function to "nearIt", everthing compiled correctly. Apparently "near" is now a Microsoft reserved word in the "windows.h" file?? In any case, thanks so much for your help!! |
