Date/Time: Wed, 15 Jan 2025 23:54:49 +0000
bitmex - DOM coloring is wrong
View Count: 1350
[2017-08-25 17:12:49] |
Todd - Posts: 62 |
Please see attached. Coloring in DOM does not reflect current bid/ask or last price execution. |
bmex - dom color.jpg / V - Attached On 2017-08-25 17:11:37 UTC - Size: 37.42 KB - 470 views |
[2017-08-28 03:01:14] |
This will be solved in a couple of weeks once we have direct market data integration to BitMEX.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-28 03:01:43
[2017-09-26 03:56:19] |
User14653 - Posts: 15 |
Hello! Some times I have problem with frozen ask or bid, because of this, the average bid ask does not show correctly, and the color in the DOM too I pointed at the picture average bid ask(blue marker) and "frozen" ask below |
frozen ask.PNG / V - Attached On 2017-09-26 03:55:44 UTC - Size: 100.17 KB - 336 views |
[2017-09-26 04:08:13] |
This will be solved once we change the BitMEX data connection to a direct connection using our own software. We will do this right now on one of the servers.
[2017-09-26 05:08:42] |
Todd - Posts: 62 |
Do we need to perform any steps to pick up this change?
[2017-09-26 07:11:49] |
No there is nothing special to do but it only has been done now on one of the servers. Also any symbol that ends with -PLNX, will no longer update from the updated server. The new suffix is -BMEX for those symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-27 12:54:08] |
Hello! thanks for the help please tell me whether it is possible to remove abbreviations in the DOM? how to make so that the volume did not show 10k, I would like to see 10000? |
[2017-09-27 14:08:51] |
Todd - Posts: 62 |
Yeah, the DOM is basically unreadable due to the number formatting convention. It fits traditional markets, but not bitcoin. Probably colored bars of varying length is the way to go. |
[2017-09-27 14:27:35] |
Todd - Posts: 62 |
Another way to skin this cat would be to introduce configurable grouping into the market depth window. For instance, group into $5 levels, etc. I was kind of shocked to find SC didn't already have this functionality, although perhaps I am overlooking it.
[2017-09-27 17:15:56] |
please tell me whether it is possible to remove abbreviations in the DOM? how to make so that the volume did not show 10k, I would like to see 10000? Another way to skin this cat would be to introduce configurable grouping into the market depth window. We are going to add this capability. We hope within the next two months.
