Date/Time: Thu, 23 Jan 2025 15:03:56 +0000
Can percentage/slope degree be used to create alerts
View Count: 1273
[2017-08-24 23:21:00]
Devil_On_WallStreet - Posts: 67
I'm curious if/how can I figure percentage into alerts... Example would be To create an alert when a wick is 45% of the total range of candle...
Also would like to be able to create a condition where angle degrees is used... Example would be a moving average has been >= a 45 degree angle for X amount of bars
[2017-08-25 00:16:00]
As far as doing a percentage calculation involving the body to the High to Low portion of the candlestick, we have prepared example #36 for this:
Study/Chart Alerts And Scanning: Alert Formula Examples
Date Time Of Last Edit: 2017-08-25 00:17:41
[2017-08-25 00:19:09]
To use the angle of the study in a formula, requires that you use the Study Angle study:
Study Angle
Here is the documentation to refer to the study:
Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart
Also refer to the prior post above.
Date Time Of Last Edit: 2017-08-25 00:20:06
