Date/Time: Wed, 15 Jan 2025 15:31:58 +0000
ZigZag Cumulative Volume syntax error
View Count: 945
[2017-08-24 20:35:45] |
User138418 - Posts: 16 |
I downloaded source for ZigZagCumulativeVolume, added the required “#incl…” & “SCDLL…” lines and added “IP_” to the front of the name (to not clobber the original). SYNTAX ERROR. Instead of fooling around with unfamiliar code myself ( I "sometimes" mess things up doing that), I will request your superb assistance. No rush, not an emergency. Thanks in advance. IP_ZigZagCumulativeVolume.cpp: In function 'void scsf_IP_ZigZagCumulativeVolumeStudy(SCStudyInterfaceRef)': IP_ZigZagCumulativeVolume.cpp:158:99: error: 'AccumulateZigZagVolume' was not declared in this scope AccumulateZigZagVolume(sc, AccumulatedVolume, ZigZagPeakType, VolumeTypeToAccumulate, ZigZagReset); |
[2017-08-25 03:37:58] |
This means you also need to include this function: AccumulateZigZagVolume above your study function.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-25 03:41:16
