Date/Time: Wed, 15 Jan 2025 17:38:22 +0000
Request about videos, order management panel & options explanations, ecc.
View Count: 1062
[2017-08-24 20:18:27] |
fs26 - Posts: 7 |
Hello Support, i have some questions about Sierra if you please: > Do you have a youtube channel with explicit videos explaning the features of the software and/or videos inside the help .. ? > Do you have exhaustive webinar that explains how to use all the stop options and the order panel ? > How to add a stop after a new limit order without an initial stop ? > Is it possible to visualise all the orders passed on a simulated account ? > I did not see the Range bar option in the graph draw type ? Is this normal ? > How it is possible to stop the message log that generates a notepad file coming out too often ! Did not find the option to close it. Thanks. |
[2017-08-26 15:15:55] |
> Do you have a youtube channel with explicit videos explaning the features of the software and/or videos inside the help .. ? > Do you have exhaustive webinar that explains how to use all the stop options and the order panel ? Videos The best reference is going to be our documentation. Refer to: Overview of Trading > How to add a stop after a new limit order without an initial stop ? Chart Trading and the Chart DOM > Is it possible to visualise all the orders passed on a simulated account ? > I did not see the Range bar option in the graph draw type ? Is this normal ? https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar > How it is possible to stop the message log that generates a notepad file coming out too often ! Did not find the option to close it. https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-26 15:18:14
[2017-09-05 15:46:20] |
fs26 - Posts: 7 |
Sir, I would like to have other precisions: > Is it possible to add the default commission of a the specific asset that is traded in order to visualise the real profit or loss on a triggered order ? (On the horizontal line of the order directly on the chart obviously..) > Is it possible to hide the former orders passed on the market in order to have a clearer overview of a chart ? Not erasing them but hidding them choosing perhaps the number of days to hide them. > Is it possible to have a sort of Pop Up coming out when an Imbalance occurs on a specific Footprint chart Check the file attached (the imbalance of 93 contracts in red in the top left area) > Is it possible to receive a sound, pop-up or even SMS when the price cross a specific moving average, VWAP or touch an area such the SD3-SD4 ? Thanks for your kind help ! F. |
sc_sierracharts_Footprint_4TReversal_Imbalance-SHORT_050917-.png / V - Attached On 2017-09-05 15:42:03 UTC - Size: 33.65 KB - 277 views |
[2017-09-06 16:58:13] |
We are going to require a paid account before we provide further support. Follow the instructions below: Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
