Date/Time: Mon, 20 Jan 2025 04:12:55 +0000
[User Discussion] - Window won't load in proper order
View Count: 1017
[2017-08-24 19:00:17] |
User432504 - Posts: 73 |
SC: I have ordered the sequence that my charts and / or dom's should be displayed on my computer task bar. However, even though the order is set under Window > Windows and Chartbooks, SC will not maintain this order. For example, I have the HG chart set to be 3rd after my GC and NG charts but instead, the HG chart loads after all the dom's no matter what the sequence is under Window > Windows and Chartbooks. Please let me know how to fix this. |
[2017-08-25 03:33:48] |
We do not think a program can control the order of windows on the taskbar. In any case we do not see how we can help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-25 03:34:05
[2018-05-24 03:26:04] |
SC: To follow up on the order of charts displayed on the taskbar...when I log in the charts on my taskbar that are detached are always out of the order that I would like. Therefore, I just set them correctly by detaching and attaching as appropriate. After I have the charts in the order i would like, they will stay there unless I open a new chart book. For example, if i have the chartbook named 1 in the order i desire and then i leave it that way and then i leave chartbook 1 open and then open the chartbook named 2, it will re-order the charts in chartbook 1, even though i did not close chartbook 1. This reorder while the chartbook 1 is open only happens if i chose to look at another chartbook, in this example it is called chartbook 2. I hope this makes sense. I don't think this is a windows function; but, i could be wrong. Could this be something that needs corrected in SC somehow? Thanks in advance for a fast and stable platform. Date Time Of Last Edit: 2018-05-24 03:28:40
[2018-05-24 04:37:56] |
There was an issue that might be related to this that has been resolved. Update to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-24 23:13:42] |
SC: Updated to the current version and Nope...that doesn't fix. Still the same problem?
[2018-05-24 23:48:49] |
We cannot provide further help with this.
