Date/Time: Wed, 15 Jan 2025 15:22:27 +0000
My trader activity log is not capturing my detached charts and DOM
View Count: 1224
[2017-08-24 18:55:05] |
User830652 - Posts: 21 |
I have gone over the technical docs and it appears that my config is correct. Thank you |
Trade Activity Log 3.png / V - Attached On 2017-08-24 18:53:09 UTC - Size: 1.32 MB - 346 views |
[2017-08-25 03:04:08] |
Here are the instructions to use the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Make sure you are following through the steps. Also refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#KnownReasonsForMissingOrderFillsAndSolution Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-28 01:40:39
[2017-08-25 08:39:25] |
Thank you for your response.
[2017-08-25 08:41:45] |
Completed your suggested readings. I am not finding how to add accounts to the trade activity log. I believe that is the basic start point, add all of my accounts. I have searched within the website and found no specific instructions. Thank you |
[2017-08-28 01:42:38] |
There is no need to add Trading Accounts to the Trade Activity Log. The order activity from Sierra Chart and the order fills received in real-time, are going to automatically be added to the Trade Activity Log for the account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-28 11:28:45] |
Thank you. I have gone through your documentation, again. What am I missing that will capture trading from my three DOMs / charts for GC, CL, and ES? My trading activity log is only capturing my ES trades. |
[2017-08-28 14:08:41] |
Is the trading activity which is missing, done directly with Sierra Chart?
[2017-08-28 15:16:40] |
No. Good point. My ES trades are from my DOM associated with my ES chart. My other two charts (GC and CL) are from different charts on two different monitors. So I trade each (GC and CL)from the DOM. I cannot figure out how to link my GC and CL DOMs to the charts. More reading links on how to do this? Thank you |
[2017-08-28 15:27:43] |
If the answer is no, we can definitely not help with this. This is what the documentation we already linked to explains. This is not something that is within our control and it is not something within your control. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-28 15:27:59
