Date/Time: Wed, 15 Jan 2025 18:06:08 +0000
How to create customized button to change TPO Time Interval?
View Count: 1013
[2017-08-24 16:00:21]
JohnnyT - Posts: 22
Is there a way I can simply press a button to change the TPO Profile Time Period Length Unit to either Daily, Weekly, or Monthly?
[2017-08-25 03:13:06]
We will see if we can automatically support this.
[2017-08-30 04:48:28]
In the next release, this will be supported just simply by changing the bar timeframe to Daily, Weekly or Monthly in the same way you do normal chart bars.
Refer to:
Changing Chart Bars Period
